Te koop: Powercommander POD-300 display
Berichtdoor Oost-TL1000R » 07 dec 2017, 14:56
Te koop:
€225,-
The POD-300 is an accessory display for Dynojet devices that support DJ-CAN; including the popular Power Commander V, AutoTune, WideBand 2, and CMD.
Simply connect the included CAN cable and you’re ready to go; there’s no need to tap power or deal with other messy connections.
Need to adjust your tune in the field, or datalog the supported channels to further refine your tune? No problem, with the POD-300 you’re just a few clicks away from taking advantage of the many features with it’s easy to use menu system.
POD-300 Features
Real time fuel adjustments
Display channels real-time: RPM, TP, map position (when using map switch), duty cycle, fuel change, speed, pressure, ignition change & wideband air/fuel ratio- (w/WB2 or AutoTune connected)
Weather resistant for use in all conditions
Log channels saved to internal memory and can be viewed / analyzed with Dynojet’s PowerCore Software
High contrast display, viewable in direct sunlight
3 Programmable light alarms
Re: Te koop: Powercommander POD-300 display
Berichtdoor Loki » 07 dec 2017, 23:36
Wie heeft er een PC5 op z'n TL? :D
Berichtdoor Dvis » 08 dec 2017, 08:17
Loki schreef:Wie heeft er een PC5 op z'n TL? :D
Haha ik denk niemand
Berichtdoor f2ride2001 » 08 dec 2017, 11:42
Kwou net zgeggen, de TL is 20 jaar oud...... Althans de mijne :D
Berichtdoor Dvis » 08 dec 2017, 12:51
f2ride2001 schreef:Kwou net zgeggen, de TL is 20 jaar oud...... Althans de mijne :D
Die van mij ook, bijna antiek :lol:
